Mar 10, 2017 20:55:49 GMT 1jackal83 said: Hey alll!
You can also install firmware for IQI I3 on our Domino DMN368 / Lemfo LF16.
Works like the others, just a different watch faces.
It can be found here mega.nz/#F!clIRkSpZ!X_kDwHqXDnGy11WSK1wI2w!FxJRUTrB
Thanks, it works. Yes, it's just the same with some other icons and watch skins. What's about IQI l4, is it compatible as well, do you know?
Hey guys, are these updates (https://mega.nz/#F!clIRkSpZ!X_kDwHqXDnGy11WSK1wI2w!g5QhGaBJ and so on) always state-of-the-art? I’ve heard that there is a new FW for KW88, but I can see here only the old one. So I wonder whether there are new versions for DM368/LM16 and so on as well … Any hint?
Apr 20, 2017 11:19:29 GMT 1yawa said: Hey guys, are these updates (https://mega.nz/#F!clIRkSpZ!X_kDwHqXDnGy11WSK1wI2w!g5QhGaBJ and so on) always state-of-the-art? I've heard that there is a new FW for KW88, but I can see here only the old one. So I wonder whether there are new versions for DM368/LM16 and so on as well ... Any hint?
Apr 20, 2017 11:19:29 GMT 1yawa said: Hey guys, are these updates (MEGA and so on) always state-of-the-art? I’ve heard that there is a new FW for KW88, but I can see here only the old one. So I wonder whether there are new versions for DM368/LM16 and so on as well … Any hint?
any new updates will be uploaded to the site:)
in “near time”? they say, there is a new 20170328 FW for KW88 for example. If it’s true then this FW is already about 1 month old.
The iqi i4 has 16gb memory and 1 gb ram, is that correct? Theres no problem installing the i4 firmware into the dm368?
I've just installed the very last version for I3 (20170518) on my DM368, running 1A, so no need to try I4. And I've got a new WiiWatch app on the phone (instead of ugly WiiWear).
May 23, 2017 13:57:09 GMT 1teamrobracing said: The iqi i4 has 16gb memory and 1 gb ram, is that correct? Theres no problem installing the i4 firmware into the dm368?
And I must unfortunately say, that I'm back to the previous version. Both the new version as well as WiiWatch are buggy and not suitable (huge battery drain, problems with notifications, unstable ...).
The I4 firmware is not suitable for the DMN368 / LF16. It’s a different hardware platform with 16GB instead of 8GB in the DMN368
You need to flash the I3 version
Make sure the watch is off (disconnect and reconnect battery f.ex.) and flash different firmware.
When watch is off and connected to USB it behaves like a “modem”. SP flash tool uses this mode to flash firmware.
Jun 3, 2017 18:13:42 GMT 1CableLeecher said: The I4 firmware is not suitable for the DMN368 / LF16. It's a different hardware platform with 16GB instead of 8GB in the DMN368
This is not correct. I3 and I4 run very well on both DM368 and LF16. I'm actually running I4 on my DM368.
I4 doesn’t run on my DM368 it showed just a blackscreen and didn’t boot.
The adapted version from pablo for 8GB devices worked out of the box…
Jun 20, 2017 11:07:15 GMT 1yawa said: This is not correct. I3 and I4 run very well on both DM368 and LF16. I'm actually running I4 on my DM368.
I4 doesn't run on my DM368 it showed just a blackscreen and didn't boot.
Very strange. Smth was wrong during installation maybe? Another / wrong version? Actually I’m running the release taken from here (MEGA), version 20170425 (with HEHUI!). I’ve also trying the very last version but it was too buggy, especially the new smartphone app.
Nope, I tried it several times. As far as I know there are 2 different hardware revisions and also 2 different types of displays. HEHUI and AOU and I chosee the correct one. Mine is also a HEHUI. I’m using now the latest version which runs like a charm.
The I3 is a 1:1 hardware clone of the DM368/LF16 from a technical perspective. The I4 on the other hand has 16GB instead of 8GB and 2 possible types of memory chips: Hynix and SMC. Maybe the difference in our DM368’s is also the different memory chips.
Jun 20, 2017 11:33:39 GMT 1yawa said: Very strange. Smth was wrong during installation maybe? Another / wrong version? Actually I'm running the release taken from here (https://mega.nz/#F!clIRkSpZ!X_kDwHqXDnGy11WSK1wI2w!B8RDgQhI), version 20170425 (with HEHUI!). I've also trying the very last version but it was too buggy, especially the new smartphone app.
Nope, I tried it several times. As far as I know there are 2 different hardware revisions and also 2 different types of displays. HEHUI and AOU and I chosee the correct one. Mine is also a HEHUI. I'm using now the latest version which runs like a charm.
The I3 is a 1:1 hardware clone of the DM368/LF16 from a technical perspective. The I4 on the other hand has 16GB instead of 8GB and 2 possible types of memory chips: Hynix and SMC. Maybe the difference in our DM368's is also the different memory chips.
Mike
Different memory chips? Well, it sounds plausible, right. Another question - so you’re happy with the very last version which runs with a new app? Are you happy with the app as well? Stable and furthermore - no battery drain?
Jun 20, 2017 12:07:24 GMT 1CableLeecher said: Nope, I tried it several times. As far as I know there are 2 different hardware revisions and also 2 different types of displays. HEHUI and AOU and I chosee the correct one. Mine is also a HEHUI. I'm using now the latest version which runs like a charm.
Mike
To be honest, I never really used any of those apps, I’m using all my SmartWatches standalone with a SIM-Card. I have 4 Multi-SIMs for a single phonenumber so no need to swap it or to tether to a Smartphone.
I also never had any issues with batterydrain so far.
Same it did not work on my Dm368, I3 worked fine but the watch shows i3 fw as i4 and i am satisfied with new i3 fw and wiiwatch app, although the app is missing app notifications control but the UI of app and watch is nice and battery life improved for me too.
