Hi to all,
Has anyone installed Finow X5 plus OTA 170111-148413.
I have just received and am unsure if is safe to install.
Hi to all,
Im installing now will edit this if i know something.
edit1 : no changelog found atm so will look around on the watch to find something
edit2: it looks like they fixed the transparant like background when selecting something (you can test it with check for updates option), does the screen looks crisperer ?? probably my eyes are fakked up but if someone can confirm.
Could you share OTA file, please?
I’d like to install it but I’m rooted and cannot go with standard way…
Hi Rufik
Do you know the folder name that the down load file would be sitting in. I have gone through the file manager and cannot see anything that resembles the OTA file .
So far only found new option on GPS where you have choices to select ‘High Accuracy/Battery saving/Device only’ Mode.
Thanks to all,
Will take the chance and install tonight.
The 170111-148413 OTA looks like it MAY have fixed an issue where cellular drops out after a couple hours of idle time. I still want to give more time to make sure before I upload a full flashable.
Three option for gps also on LEM5 after the update.
If i am able to romdump it tomorow i can defently upload it here with pleasure.
Do you romdump it with that program where you flash your rom with. ?
Jan 13, 2017 23:30:52 GMT 1 antony123 said:Jan 13, 2017 17:40:15 GMT 1 @testaccount said:
will i able to flash it to my watch using the flash tool? cause my watch is totaly bricked right now.Thanks
Jan 14, 2017 14:23:48 GMT 1 zabadok said:Jan 13, 2017 23:30:52 GMT 1 antony123 said:
Flash the 161125 firmware then check for the OTA on the watch.
Jan 14, 2017 21:00:52 GMT 1 @testaccount said:Jan 13, 2017 23:30:52 GMT 1 antony123 said:
Thank You
That is a relief, Zabadok!
antony123, I updated my watch 2 days ago. Works fine indeed!
