If manages to install the lem5 Firmware on my AIR, its works really great! Keyboard and Batterylife is definatly better than with the x5 AIr Stock firmware.
if you like I’ll upload you the necessary files.
Aug 11, 2017 15:26:19 GMT 1 Exellent said:
If manages to install the lem5 Firmware on my AIR, its works really great! Keyboard and Batterylife is definatly better than with the x5 AIr Stock firmware.if you like I’ll upload you the necessary files.
Yeah the preloader i have is from the stock air firmware (which i also got now). also the lk file (which i’m not shure what this is for ?!)…
Also twrp 303 is working fine
Exellent: Have you tried the GPS using the Lem5 FW?
I’m giving up using the X5 Air to navigate. Can’t get a fix with any program other than MTK Engineer…
Aug 12, 2017 14:33:37 GMT 1 tigermilk said:
Exellent: Have you tried the GPS using the Lem5 FW? I'm giving up using the X5 Air to navigate. Can't get a fix with any program other than MTK Engineer...
No haven’t tryed yet. But ATM I’m testing a few different os versions. And i’ll Report you about the gps.
Want to use the gps for my running workouts but it just wont work
any news on this ? is GPS working ?
Apparently there is a December 06, 2017 OTA for the X5 Air that fixes the GPS. Saw it here in another post, so look around. Only posting here in case you are checking back on this thread for an answer.
No ota available for me ? Just tried
how did you do it? have you made sure not to mark the preloader? if i'm not mistaken they are 2 different watches so you can't flash it with different firmware it could brick the watch.
THANKING YOU
DRSAIDALALVI
I have heating problem in x5 air any solutions??
