I am new to smartwatch. I bought FInow X3 plus. But I am having a strange situation. The packging has written 512 ram and 4 gb rom but the clock says X3plus. Whats up with it? any user here?
And I dont see any official website. So where to find firmwares and other infos? Is there any pc driver for the phone to use the storage for copying stuff?
I have tried many apps and most dont work. It shows installed with wearable app manager but doesnt open. Why is that? Where can I get a list of working app?
Lastly, What custom watch faces are compatible with X3 plus?
don’t take care about the packging, i have the same but my phone he’s realy the X3 Plus.
You can see your storage, you have more than 4gb.
You can see more information about your watch under Parameters -> About device
To update the firmware, connect your watch to internet with wifi and do the OTA update.
Parameters -> About device -> Update
You can see more information about your watch under Parameters → About device
Parameters → About device → Update
Oct 2, 2016 15:47:19 GMT 1RASC Moderators said: Connection to the PC is already covered in the FAQs and guides section. Basically Windows hates MTP which is what Android uses to connect.
I wen through FAQ but as it says I need to locate the driver manually, there was no link to download the driver? I need the driver right? lol
Windows detection select a wrong driver, you must manually select the right driver. This good driver is already installed.
All is explain here : /thread/75/guide-usb-mtp-device-issue
