Finow X3+ GPS doesn't work
Hi.
I’ve an X3 plus since september.
I remember it worked (not perfectly due to the antenna inside the wrist) but now it doesn’t work.
I downgraded it because of battery drains… and now I ope the gps test and I can see the SATs but it is not able to use it. It’s not fixed.
I was trying to open TWRP by clicking both buttons and I entered in a factory menu? Maybe I modify something in the GPs option while trying to exit that menu.
Someone could tell me the right options on the menu?
maybe is that the problem?
Jun 26, 2017 8:12:54 GMT 1 ogutierr said:
Hi.
how did you downgrade? did you flash the stock rom?
hi. yes. stock w612_X3+_160927 (from here, on the forum) instead of the last one I updated via OTA.
It was an useful watch due to the battery draining. Now I can use again the watch
