Feedback review of kw88 after months of usage
If no please indicate why.
If yes, indicate if you have any mod (Rooted/greenify/etc…)
Jun 25, 2017 7:42:39 GMT 1 bmbulahan said:
If no please indicate why. If yes, indicate if you have any mod (Rooted/greenify/etc..)
Pls also note how long you been using your smartwatch
I have the watch for nearly 7 months now. I use it every day. Not for what I wanted to in the first place, but you adjust to the possibilities of the watch.
PushBullet is the app I use the most together with my domoticz app. I can adjust my home with my watch from anywhere in the world.
Don’t expect a life changing experience, it’s just ok. Nice watch, good quality and build.
Pro’s: The screen (brightness and resolution), full on android with all the possibilities of the play store.
Con’s : The screen (not many apps support it) Battery life (heavy use, with the screen constant on will give it a maximum of 8 hours. That’s not enough for anybody, so you have to adjust your needs)
KW88 with stock firmware
About the same timeframe usage with globalassist, which was since december 2016 for me. Previously with Eric’s launcher 1.1.6, i could get from 8am-8pm with 20% battery left. With Eric’s new version 2.2.4, i am left with 50% battery for the same timeframe usage of 12 hours. This is with BT on, wifi and cell off. Notifications work pretty well with the watch and phone for me since the latest version. Previous versions were pretty buggy.
I’m also on december 2016 FW and have not updated the FW since. Though i do know that there are 2 newer FW versions.
It’s my daily watch and i’m pretty satisfied with the KW88. No major issues to complain about nowdays.
Jul 18, 2017 6:33:13 GMT 1 plateau said:
About the same timeframe usage with globalassist, which was since december 2016 for me. Previously with Eric's launcher 1.1.6, i could get from 8am-8pm with 20% battery left. With Eric's new version 2.2.4, i am left with 50% battery for the same timeframe usage of 12 hours. This is with BT on, wifi and cell off. Notifications work pretty well with the watch and phone for me since the latest version. Previous versions were pretty buggy.
Which BT app you use to get notification on watch via phone let me know please
Sept 13, 2017 6:40:18 GMT 1 smongar said:
most likely one of the three:
watchdorid.
m2d.
the stock - watch helper.
watchdorid.
m2d.
I use Wiiwatch, it works fine.
Jun 30, 2017 12:08:03 GMT 1 globalassist said:
I have the watch for nearly 7 months now. I use it every day. Not for what I wanted to in the first place, but you adjust to the possibilities of the watch. PushBullet is the app I use the most together with my domoticz app. I can adjust my home with my watch from anywhere in the world. Don't expect a life changing experience, it's just ok. Nice watch, good quality and build. Pro's: The screen (brightness and resolution), full on android with all the possibilities of the play store. Con's : The screen (not many apps support it) Battery life (heavy use, with the screen constant on will give it a maximum of 8 hours. That's not enough for anybody, so you have to adjust your needs)
Can you please advise if Pushbullet (or any other app) can allow my KW88 to remotely connect, via WiFi connection, to my phone. Like Android Wear Cloud Sync does? I’m new to this and rather ignorant and would appreciate any help. I am using Watch Droid to connect watch and phone. Thanks.
just a few days of using. starting hanging and works erratically after installing watch droid. some bluetooth issues are definitely there. call worked incoming with wiiwatch,
but strangely it would always call a strange number always when i tried to dial an outgoing call. very strange behaviour. buggy i thought.
