Hello everyone, after my appllp 9 stopped working I’m searching for a new FAW. But it seems, there are no newer FAWs with integrated sleep tracker, is that right? Can you recommend me an available product, that is not too bulky?
Thanks a lot!
The lem16 & appllp 2 pro, both running android 11 have a native sleep tracker. All of the android 9, 10, & 11 watches will run sleep as android if you want a stand alone app.
Thank you very much!
Problem with sleep as android would be, that you have to start it manually, is that right? Or is there a way to start automatically when you fall asleep?
I always start it manually. But it has a setting to autostart. I havent tried it. I assume thpugh, that the app would have to always run in the background to sense the start of you sleep.
Thank you, I will try that! ![]()
