LineR
February 27, 2020, 8:13pm
Facer watchface renderer
GitHub repository
Support:
Draw images
Draw dynamic images
Draw draw shapes
Draw text (contain bug, im working on it)
Draw text effects
Draw icons
Ambient mode
Round/Square mode
Protected and not protected watchfaces
All rights for this repo and code reserved by me. If you want use this engine in your project - request permission.
This project will be updated, when it will be stable and bugless i include it to my launcher.
LineR
February 28, 2020, 6:31am
2
Update
Add some time tags, fix time rag parsing issue
LineR
February 28, 2020, 7:29pm
3
Comparing facer web renderer with my java version
Normal mode
Ambient mode
Issues with weather tags, im not implement it for now, and draw animated images with math shapes
LineR
February 29, 2020, 8:31pm
5
Is anyone have a pack of .face skins?
LineR
February 29, 2020, 9:45pm
6
New compare https://youtu.be/XnPRLJLuqfw of FacerEngine.
Publish with sources also a apk file?
LineR
February 29, 2020, 10:06pm
7
Hi, thanks for your work.
I installed the apk, in Samsung S8.
The installation went well, but I can’t open the .face file and when I select START DRAW the program closes.
What am I doing wrong?
LineR
March 1, 2020, 8:01am
9
Its system exception. In my phone it crash too. Reason is even app have permission to write and read internal storage it cant unpack face skin. However it works on Android 6-7. Android 8-10 have security exception
LineR
March 1, 2020, 8:04am
10
Wait for update. I make feature to draw skin without unpacking file, or give manually all possible permission for app in settings
LineR
March 1, 2020, 8:10am
11
Strange thing, i was try again my app on phone and after again selecting skin it works. Hmm
Thank you very much.
Great
LineR
March 1, 2020, 3:39pm
14
Repo updated with build apk.
I implemented selecting watchface without unpack
Add some weather tags and math function
thank you very much, now the visualization works and also the START DRAW.
abhifx
March 1, 2020, 4:49pm
16
anybody testing this? seems promising
LineR
March 1, 2020, 4:53pm
17
I’m developing it, so as you can see i also testing it)
LineR
March 1, 2020, 10:00pm
18
Update source with apk.
Change log:
Full support for ambient square mode (in older version it contains a lot of problems)
Smother rotation tags
Update code structure and optimization
If anyone want help me with this project, you can create pull request with your improvement or bugfix. Project is open
Cause its hard make all work alone, working together its interest and funny. Also it speedup development
LineR
March 4, 2020, 6:11pm
19
Update
Changes:
Support clockskin format to
Fixes with facer format
Now render can draw both formats, ClockSkin and Facer.
Select Facer .face file to draw Facer
Select ClockSkin .zip file to draw ClockSkin format
APK Updated. All rights reserved by me
