for a few days now my Lemfo has been emptied in less than 5 hours!
What’s going on?
It could be a number of things . Usually a rogue app or system change . Factory rest will usually fix this . If you dont want to do this you can dig a little deeper and see what you recently installed which is causing the problem
thank you for your prompt response.
I will reinstall it …
thank you
Did you give a try ? Any Luck ?
The chances of this being a faulty battery are slim
thank you all
I reinstalled the OS and everything went back to normal =)
however my watch only serves me for:
time - phone - message - alarm - photos
that’s all !
so I don’t understand, but in short it works
Thanks again
. Are you saying something is missing after the factory reset ? Or you dont know what initially caused the battery drain
i dont know what initially caused the battery drain
merci
