Don’t know if I ever will succeed , if I will ever come far…
But this seems to me like a nice watch to make for my D5+ .
I’ll definitely will make a beginning…don’t wait up for it for this will be the first one ever for me so I expect it to be a long term project
It looks a very straight forward watchskin… the sub/top dial could be for battery level… I’d like a second hand but you might be different… if you’re lucky you might be able to find a “shared” skin that has a tourbillon that you could copy/use… enjoy your project
@Martin_Nijhuis , hands on work. Even if you do not get in perfection, only work to do is a good reputation. Good work and if you have any issue, we are here to help you.
Update >> Did it…consider please it’s my very first CF…
Based on the Earnshaw 1805 https://www.thomas-earnshaw.com/
but with own touch, a copy here a paste there .
Other hands …added a second hand.
Don’t know if the battery-hand is pointing correctly.
CSM doesn’t show how it appears on my watch (D5+) and this is by far the most difficult hand to get right.
Thanks to all the watchmakers here (borrowed and learned from them)
Hello Martin, this looks amazing. I noticed that when I download your link i do not get the same display as your image. I do not have the day of the week and also the date , month and year are not showing up. this is what I get in your download.
@A1_Web please download again. I updated the photo because I changed the CF. If you download again (the newer cf) and replace please show again if it’s OK. If not I must have done something wrong and I’ll take a look first thing tomorrow.
@A1_Web I have replaced both the file and the download links here .
It should be correct now…please try. @Andrew_Davis Made it with CSM so it should work on both.
The only thing csm wasn’t showing right was the battery hand.
