I noticed that bangood lists the lem5 pro’s 3G frequencies as 850 / 2100 but gearbest lists it as 850/1900/2100MHz (1900 support would open up a 2nd band on AT&T and open up T-mobile for use in the U.S). I’v only seen the Lem5 pro listed at two other locations, but they have 1900 listed as well. I wonder if anybody had any insight into the issue or could install something like Network Cell Info Lite to see if it has 1900Mhz support (assuming you have it in your market).
Oct 19, 2017 20:31:10 GMT 1 devin40t9f said:
I noticed that bangood lists the lem5 pro's 3G frequencies as 850 / 2100 but gearbest lists it as 850/1900/2100MHz (1900 support would open up a 2nd band on AT&T and open up T-mobile for use in the U.S). I'v only seen the Lem5 pro listed at two other locations, but they have 1900 listed as well. I wonder if anybody had any insight into the issue or could install something like Network Cell Info Lite to see if it has 1900Mhz support (assuming you have it in your market).
Yes it does have the 1900 band for 3G
Nov 3, 2017 8:48:05 GMT 1 devin40t9f said:
No problem 👍
