Does anyone have firmware for the DM100?
Not LEMFO and not Ticwear. Maybe Domiwear?
I flashed it with a LEMFO firmware, since then there are only flickering spots on the screen. Logging in music can be heard, only normal images are missing …
there’s two versions of the firmware, I guess you have tried the regular one, so you should try the D version instead:
Otherwise, thank you for your quick response. Good let the end of the day…
It’s much better now. The picture looks just a little striped. The third display version may already be ok.
I have a feeling that you are still using the wrong firmware.
