DM30 low accuracy location
Please i need help. My watch when on data has false location. it says low accuracy and that needs calibration - to move my watch, what is not working. It is everything ok when wifi is on.
Did you factory reset before using ? I would suggest you do. Check for a firmware update / install and factory reset again
Also make sure all apps updated
I know this question is a few old, but I will answer to keep the record on history for the future.
This occurs on ANY smartphone or smartwatch that doesn’t have an integrated compass.
That’s why you can’t use the compass option on Google maps when you tap the blue dot on the right bottom corner. Doesn’t mean you have a low accuracy location anyway.
