Disable X5+ battery low sound?
Is there a way to disable/change/mute the battery-low sound that comes at 30% and 5% ?
I also search for this. Its annoying…
maybe the sound file is somewhere accessable and deleteable or replaceable?
Maybe I got it. I found a app in the all apps list called “com.mediatek.batterywar…” and forced to stop it. Maybe its killed now. I will have to test it.
You can reach this, when you install through playstore the app “settings search” (https://play.google.com/store/apps/details?id=net.infiniti.touchone.touchone&hl=en) and search for apps. Then you have the settings like on a normal smartphone.
Mar 21, 2017 23:39:19 GMT 1 chromax said:
Maybe I got it. I found a app in the all apps list called "com.mediatek.batterywar..." and forced to stop it. Maybe its killed now. I will have to test it.
Good idea!
Unfortunately it starts again after a reboot.
I´m sure there is a way to completely disable it. But I´m always afraid of bricking the device when playing around with the services. I will test it to get sure nothing breaks without this.
