Diggro di05 firmware
I need firmware for this watch cant find it anywhere uninstalled kingroot now watch wont start watch is diggro DI05
if this watch is q5 or q3 you can flash it with their firmware but you need to be sure which model do you have, check with hardware info app.
i have diggro DI01 and use KW88_CS1_B_GSM_PHT_20-BT.171109, you can use but dont sellect preloader! if select preloader clock not working after flash complete
Di01 work fine with kw88 rom ?
Where i can download firmware ?
Di01 work fine with kw88 rom ? Where i can download firmware ?
2 different watches different software, it is better to flash it with the firmware of the q5 cos it is the same watch. you can find it in firmware section on the x series.
Please help me when I update my firmware
I want the factoryfirmware of diggro di 01
this one is the x200 we do’nt have it’s firmware you might be able to flash it with the les1\thor firmware but can’t be sure and it can brick the watch if it does’nt suit it and you do’nt have the original firmware to back up or to flash if needed.  why do you want to update your watch? do you have issues with it?
i have diggro di05 too and stuck because too many clockskin. is there anybody have di05 firmware please? i have flash it with dm368 firmware an now its bricked. pleAse help me guys…
Feb 9, 2018 19:31:31 GMT 1 juntax79 said:
i have diggro di05 too and stuck because too many clockskin. is there anybody have di05 firmware please? i have flash it with dm368 firmware an now its bricked. pleAse help me guys.......
check the specs of the watch if they are the same as the q3 or the q5 then you might be able to use the firmware of one of them, but again they need to with the same specs.
thanks for the help, im looking for q3 plus and its look identical, but now the problem is when i flash with spft the error code is enable dram failed. what should i do now?
are you sure it is the q3? i was more thinking it is the q5, that is the problem with the models:/ can you upload a pic of the msg? cos it sounds the firmware is'nt the right one.
are you sure it is the q3? i was more thinking it is the q5, that is the problem with the models:/ can you upload a pic of the msg? cos it sounds the firmware is’nt the right one.
my bad, yes its more identical to q5, but where can i find the firmware?
i have found the firmware of finow Q5 and im successfull flashing it onto Diggro di05.
thankyou so so so much sis…
now i have finow Q5 on my wrist hehehehehe
i’m glad you have your watch working, can you write plz the model you have and which firmware you used so other user can benafit:)? thanks:)
i got it from here
/thread/1672/finow-q5-ddr-firmware
credit from pablo11
here is the link
First version w618_wgl.q5_ddr3_64g4g.common.80.emmc.w.s.170928.flash
goo.gl/hEVgHc
Hi do you still have the flash file?
I have this one worked ok do not flash preloader https://drive.google.com/file/d/0B3xyOuab2f-OenpPa096eGYxSjA/view?usp=drivesdk
