Every time I switch on my watch it defaults to zero media and ring volume (even though I would have set desired level before switching off) and I have to keep turning on these two on restart. However the alarm volume remains where it’s been set. How do I set it to remain on set volume level?
That is a odd one. Make sure you have the latest firmware installed , factory reset and see if the problem persists
Did you set power saving mode when it reaches certain %?
