Have a finow x5+ which was working fine. I had installed many apps and faces then suddenly it went dead. Now I cannot power it up no matter what I try. I have loaded MTK drivers but it still is not recognoised by my PC to install firmware. Can anyone help? Thanks
check if the battery is connected it might be dead, have you done something new before it happened? also check for corrosion.
Sonia is a expert on “ Corrosion “
try this: connect to the charger, than press upper and middle button for 30 seconds. let me know if it restarts after?
