I have a kw88 and the charging connection is daft. Magnet type and it just comes disconnected so easily. Slightest movement and it’s off. Anyone know of a cradle or summit that would stop this happening. Times I go to see if it’s charged and the bloody cable is off. Grrrřr
Dec 3, 2017 23:05:50 GMT 1 bump1969 said:
I have a kw88 and the charging connection is daft. Magnet type and it just comes disconnected so easily. Slightest movement and it's off. Anyone know of a cradle or summit that would stop this happening. Times I go to see if it's charged and the bloody cable is off. Grrrřr
true, a great downside to this cables, the les1 charging dock might suits but not sure:)
www.aliexpress.com/item/Original-Magnetic-Charger-Charging-Dock-for-Zeblaze-THOR-Smart-Watch/32823180120.html?spm=2114.search0104.3.2.XhoI9A&ws_ab_test=searchweb0_0,searchweb201602_3_10152_10151_10065_10344_10068_10345_5000017_10342_10343_10340_5060017_10341_5130017_10541_10084_10083_10307_10539_5080015_10312_10059_10313_10314_10534_100031_10604_10603_10103_10605_10596_10142_10107,searchweb201603_25,ppcSwitch_2&algo_expid=e8a4adab-05da-47b4-a579-79f54098368d-0&algo_pvid=e8a4adab-05da-47b4-a579-79f54098368d&rmStoreLevelAB=4
KW08 came with a magnetic charging base and it is really convenient. So I got the idea to build one from a picture I saw on the RAS google plus forum of a converted apple iwatch charging stand. Using materials I already have available I thought I can do it one better and build one. Here is the result of about 3 hours work using materials I had on the boat. No more precise positioning to get a charge. Place it on the stand and walk away.
I spent the extra time to make it presentable but that is not necessary as long as it works. Use your imagination, it works better every time than searching for someone else’s solution to solve your problem.
Added: I received my H2 today and you can see that it also works on the charging base.
