Nov 11, 2016 17:54:36 GMT 1 miroul said:
Polaris59,
That is odd. Have you added the APN for your provider? Actually can you connect at all to the 2g or 3 g network to place phone calls? I am with Rogers and my X3 plus connects to 2g and 3g BUT initially, i had to manually had my APN settings in order to get data connectivity on.
I am really considering that, seems like the only one that will allow me to leave my phablet home and not worry about losing battery life in the middle of the day.
Hi Miroul
Actually my X01S picks up and displays the APN settings correctly (Both Telus and Bell, which is pretty much Rogers), and seems to indicate a good strong signal.
But there is no network connectivity, even the phone reports that the cellular network is not available.
Mind you I think Rogers is the only carrier left that supports 2G GSM, so you might be OK.
I’m guessing that the X01S does not support North American 850/900/1900/2100 WCDMA (but does work in Asia).
