D5+ not showing lastest FOTA
Hello
My D5+ has the 11/09/2016 firmware and when I hit “check firmware” it is respond "Your watch has the latest firmware.
I can’t have access to the latest OTA firmware.
Any help would be appreciated.
thanks
Factory reset?Then check it again.
Nov 3, 2016 2:37:04 GMT 1 hangman5 said:
Hello
thanks
You can install the new one 161030 via SP Flash from here.
If you want to hold your settings and apps, “uncheck” userdata on SP Flash.
Hello
thanks
He asked why he could not receive the OTA update! But I think after wired flash this issue would disappear.
Reset the watch didn’t work. I still have the “You system is currently up to date”
I wish I could use SP Flash but I just can’t install the MTK drvier on Windows 7.
So I’m stuck with a firmware that is draining my battery.
Nov 11, 2016 2:51:26 GMT 1 hangman5 said:
Reset the watch didn't work. I still have the "You system is currently up to date"
try to do the guide for installing drivers, the guide is for win10 but maybe the same as win7 (i do’nt have any pc\laptop with win7).
Yep,I downloaded no.1 firmware,there are drivers inside.
