Custom rom for Hexxa Atenea and clones.
Great the last 13 rom. The only think don’t works is the microphone.
I purchased a D5 specifically because of this ROM, even though there are newer and better spec’d devices available. Thank you OP.
Are you expecting to upgrade anytime soon? I will follow you and be a beta tester for anything you’d need.
Great work guys awesome rom… as a feature suggestion. the ability to customise the shortcuts on the native clock face… and possibly the addition of a double tap one to turn off the screen
Get my D5 today, looking forward to this ROM!
Oct 14, 2016 20:18:28 GMT 1 corvus said:
New version 1.1!! Added Easy touch for people with power button problems. Launch the app and follow the steps Now it's a userdebug version, so root menu is in developer options.
corvus, root works fine but I cannot flash anything in TWRP. Showing 0mb internal storage and the phone doesn't seem to be encrypted according to CM settings.
Please help
Cool, shitty support. Thanks
TWRP does not recognize internal storage. Have now tried both CM12 and CM13 versions.
Still waiting for support.
Can i flash this rom in smartwatch d5+
No, and don't use anyways, it's useless because you can't flash anything.
Ok, thank you
I was actually going to donate to you, but this abysmal support for a ROM you made has already made a decision for me.
will this work with lem5?
no.
Having some issues flashing this on my D5. After mucking up my original rom I tried installing CM13. Install goes fine, just like original D5 roms. When it boots first time it gets stuck at the CM logo, refuses to boot. What am I doing wrong? Im using SP_Flash_Tool_v5.1720_Win. Flasing original roms goes fine.
maybe stupid question but do you have root and custom recovery?
I had root in my previous rom before I started flashing. Do I need TWRP installed before I start flashing the CM13? Sry bit confusing flashing this watch. Been flashing android stuff since the first Galaxy S came out but flashing this watch seems to be a bit different.
Edit: Nvm I solved it
1.Reflash original rom (as I was bootlooping)
2.Root and install TWRP (Update Firmware), switch USB debugging on
3.Flash CM13 as Update Firmware
4.Winner!
Having a play now. How do I install the watch faces? Seems different to stock rom
So last night I installed CM13 Atenea1 found on needrom, the only link I could find to download the ROM anyway.
My D5 is my second phone, so I use it majorly for this purpose, I also depend on it for alarms (waking up from slumber) due to it high vibration than my main phone. I open up the ‘clock’ app to set an alarm, but only a semi circle of the clock shows (i.e 9 - 12 - 3) other numbers are below the reach of the screen of the phone, I wanted 4:00 A.M but since I couldn’t get to 4, I settled for 3:59 AM.
Before the alarm could come up, I was already awake waiting to see if the alarm will work as it always does on W812a ROM, but 3:59 AM came nothing happened (No sound, No vibration), using the current time, I set another to 4:10 AM, a toast appeared saying permission denied!..In a nutshell, the clock/alarm doesn’t work.
Secondly, I went to bed with a battery percentage of 89%, woke up to a battery at 53%. I specifically chose this ROM due to the hype and claim of 4-5 days usage on a single charge. with this, I am at a crossroad.
Thirdly, since the ROM didn’t come with GAPPS, I downloaded a pico/Marshmallow version for D5, booting to TWRP to install the GAPPS, I was unable to mount internal_sd even though it is reading 0MB
Those are my findings on a double flashing…any headway?
Did somebody installed the CM13 Atenea ROM ever to a Q7/S1/LF17 watch? They all have the MT6572 CPU
Hi. Will this work with Allcall w1?
Thanks.
i know it is a long time ago but still relevant, sadly our watches do’nt have root and custom recovery which you need to install this rom cos the developers can’t afford to buy every watch and they can only work with the ones they have.
