Update:Removed a couple of apps, still using same set up as above.I am now on Day 3 with 50% battery left! Have on airplane mode at work, check emails, social media in work breaks, fantastic battery life, will update when eventually runs out!
Update: Battery finally ran out 1pm on day 5. Best battery life I have had on any android device!
Nov 21, 2016 22:59:46 GMT 1stevea76 said: Update:Removed a couple of apps, still using same set up as above.I am now on Day 3 with 50% battery left! Have on airplane mode at work, check emails, social media in work breaks, fantastic battery life, will update when eventually runs out!
i hope the + series will get soon their own custom rom…
I decided to try the earlier version of the ROM CM 12, very good as well, however for some reason when I accessed settings and clicked on any option settings stopped, so I decided to flash CM 13 back to the NO 1 D5.
Did a fresh install and noticed in my folder with the ROM on my computer I still had the PICO GAPPS zip. I thought I would give it another go at loading through TWRP, and this time success!
I don’t know what happened, same ROM, same GAPPS zip. I must have tried 15 or 20 times previously with no luck. This time I still could not mount SD card in TWRP, but for some reason it worked!
I will see what the battery life is like now I have Google services installed.
So for those who had no luck before, and really want GAPPS try a fresh install.
Hi, Corvus. I tryed to install the rom but when finish, it’s not run. I have a Finow Q3. I reinstalled the stock rom and everything is well, but i would like to know if is it works for my watch? Thanks.
Hi sabocr I don’t have a Finow so I’m not really sure if this should work. Take the stock rom from finow and change system.img, recovery.img, boot.img and EBR files taking them from my zip file and then do a firmware upgrade. I’m not sure if this will work nor even if you will get a bricked device, because I have not tested it, so do it at your own risk.
For support a device I need this device to test my images and do the needed changes.
Nov 30, 2016 19:23:52 GMT 1corvus said: Hi sabocr I don't have a Finow so I'm not really sure if this should work. Take the stock rom from finow and change system.img, recovery.img, boot.img and EBR files taking them from my zip file and then do a firmware upgrade. I'm not sure if this will work nor even if you will get a bricked device, because I have not tested it, so do it at your own risk.
Nov 30, 2016 19:23:52 GMT 1corvus said: Hi sabocr I don’t have a Finow so I’m not really sure if this should work. Take the stock rom from finow and change system.img, recovery.img, boot.img and EBR files taking them from my zip file and then do a firmware upgrade. I’m not sure if this will work nor even if you will get a bricked device, because I have not tested it, so do it at your own risk.
FYI, Hi Corvus i installed the rom in the watch but it doesn’t work. I have a Finow Q3.
I’m redoing the work in CM13 because the base that I’m using has a bunch of strange glitches and I don’t have time to search for them, so I started again with another base. This means that I will need more time for a new version, but this new version will not have this strange problems (dpi, etc.) that this image has.
Hi corvus, how are you doing?
Are you still working on this new version? Do you have any news on it?
This version is the one that allowed me to install GAPPS.
I am personally using the other version without any GAPPS installed and this has been running without any errors. I just use most alternative apks from F-Droid.
Without GAPPS I am still achieving 4 to 5 days usage on a single battery charge.
Can you tell us what app you’re using to connect to your phone ?
ricktop, I don’t use any apps to connect to my phone, I have a sim in it, but to be honest I use Wi-Fi at work/home.
I use Lightening Launcher as my browser, Tinfoil for Facebook, Offline Calendar + Calendar Import/Export to sync calendar entries, Newpipe (lightweight YouTube frontend) all from F-droid. Chronus News widget + weather widget, Nova Launcher (apks backed up from Google Play from my phone and installed on D5) LMT from XDA & myClockskin app from yourself.
