As you can see on the image, there’s a small crack on the backside of the watch.
Between the SIM card tray screw and the camera
Another problem, I think the back case isn’t sealed up properly, which I guess is the reason why the back plate cracked.
I wanted to know if anyone else is having this problem, and if it’s safe to use this watch.
              It will be fine to use . Looks like a weak point from where the screw goes in . I looked on Aliexpress to see if you can still get replacements but nothimg . Sorry
              Thanks for your help sir!
              I have makibes M3 (Kospet Optimus)  and Kospet Optimus pro. Both watchs have the same crack as you. I think the design of Kospet Optimus is fault, thickness of the back plate is too thin. My M3’s back plate was completely broken by timepassed.
I hope this information will become useful for Kospet and manufacturer.
BR
