Hey guys,
here is a new app called ‚Droid Smartwatch Counter’ released for Android.
Have a look at the app, it is especially designed for the round display, but may work on more devices.
Here is the link for Google Play Store:
thanx
Hey guys,
thanx
You seem to have developed this app. Thank you, I’ll take a look.
Thanks for the app, I have moved your post to the correct sub category.
Thanks . Looking forward to trying this
You’re AWESOME men!!! Thanks a lot!!! I was looking for an app like this a long time, and because didn’t exist I was using the Google watch who fit very well anyway to the screen.
But this is perfect, and likes me so much more because on the video it’s being tested on a LEMP like mine ha ha ![]()
How you keep alive on background when you turn off the screen?
Thanks a lot buddy
Your welcome
Liked so much the display interface, fit exactly to the round screen.
Another quest, can be setted and exact countdown, ie. 35 minutes, 20 seconds (35:20)?
Thanks so much for seeing a need and filling it. Optimised for round faces certainly helps with the font size. One small issue, the settings cog isn’t accessible when in round face mode on my APPLLP 4 pro. To use it to change titles requires a change to square face again. Will recommend this on google play store when the opportunity presents itself. Thanks again for the app.
Hello ! in progress …
Thanx
Hello ! The gear can ONLY be used on tablets or mobile phones! Just click on the text and the menu will appear. There are additional versions in the store (choice of color, font size). Regards, Tomi
Hello Tomi, thanks for clarifying the use of the settings cog. I will stop swapping screen modes and follow your design more closely in round mode.
I am experimenting with a screen overlay app that uses gps to indicate ground speed at the same time as your countdown and stopwatch app, now that there is a better use of screen space in round mode. Thanks again for your app.
Please let me know if you get it.
Thanks!!!
Hello !
I did not get anything …
