Corrupt Clockskin Locked up Hope
I installed a Clockskin watch face from one of the more popular contributers that must be corrupt. When I sitched to this face, the watch froze and now it won’t let me do anything other than see the “always on” watchface. I tried restarting several times but that didn’t help. I have the  sim card data cable so I thought I’d be able to remove the watch face but that doesn’t seem to work. Does anyone know how to fix this? Is there a way to force a reset of the watch using any of the buttons?
Feb 25, 2019 1:25:22 GMT tsg25 said:
I installed a Clockskin watch face from one of the more popular contributers that must be corrupt. When I sitched to this face, the watch froze and now it won't let me do anything other than see the "always on" watchface. I tried restarting several times but that didn't help. I have the  sim card data cable so I thought I'd be able to remove the watch face but that doesn't seem to work. Does anyone know how to fix this? Is there a way to force a reset of the watch using any of the buttons?
I found a solution by using the "manage devices" in Google and remotely erasing the watch.
Yes long press power button you Will get home screen button on the screen just long press the home button it will take u into the settings menu there will get restore settings
Actually, this method did not work on the Hope. It just powers it off and restarts it back to the blank screen.
I had same issue. I long pressed power button and “recent tasks” came up. I then opened clockskin transfer app as it was still open in background, opened clockskin transfer on my phone and deleted the offending face. The watch then went back to its default face.
I had the same issue. I closed the watch for a long time and when I opened it I had the problem solved alone
how to see the clockskin will work on the Kospet
Is there any site available with working clockskins for the Kospet Hope ??
Yes, look into our video and also check out the new site:)
I already did and bookmarked the new site. The thing is how to be sure
a clockskin works on the hope im running standard launcher. Coz several memebers loaded clockskin that froze their watch,
and had to do a factory rest and install everything all over again
Don’t use any watch face which only works with the Universal Launcher.
***BTW GUYS, A L W A Y S LEAVE THE STETTINGS AND FILE MSNAGER IN RECENT APPS IF THE WATCH FACE DOESN’T WORK!
I already did and bookmarked the new site. The thing is how to be sure a clockskin works on the hope im running standard launcher. Coz several memebers loaded clockskin that froze their watch,
Don't use any watch face which only works with the Universal Launcher. ***BTW GUYS, A L W A Y S LEAVE THE STETTINGS AND FILE MSNAGER IN RECENT APPS IF THE WATCH FACE DOESN'T WORK!
Thanks   getting smarter  day by day
