Converting faces.
Hi everibody.
Can someone help me if there is anyway to convert .gwd files to .watch or .zip format? So I can use them on my lemfo lem5 pro?
Thank You in advance.
Hugo do Carmo.
Could you tell me what faces KW99 has… .gwd or .watch… Thanks
I can´t answer you that because mine is a lemfo lem5 pro, I´m using universal launcher.
Jan 4, 2018 13:57:17 GMT 1 leclerc said:
Could you tell me what faces KW99 has... .gwd or .watch... Thanks
I'm looking for an answer to the same question. Is there a simple primer for newbies like us?
You can also add VXP as another unfamiliar format to the above query too.
I too have a KW99 and have only managed to install watch faces that come as a complete folder (placed beneath the “clockskin” folder on my watch)
