hello,
anyone have an idea, my PC will not see my IQI i2…
if i put the USB Cable in it nothing will happend on my PC
i removed already the rubber for the pin connections… as i see it in an Video…
i installed the VCOM Driver on an old Win7 PC… nothing happend when i but in the USB Cable… only the watch says it will charge…
i want do put some Watchfaces on the Clock…
Feb 10, 2017 10:55:46 GMT 1 eviltrooper said:
hello,
go to devices manager and see if you see the watch there or an unrecognized device.
Thats the Problem! There is Nothing …
Feb 10, 2017 18:03:39 GMT 1 eviltrooper said:
Thats the Problem! There is Nothing ..
that means that the drivers are not installed if the watch chargers that means the problem is not with the watch or the charger but with software. delete the drivers from you pc, redownload them and do the guide on how to install them and then do the mtp usb installation too.
Mhh, i need the vcom driver, dies i need to disable the driver signature in windows 7 32bit too??
Mhh okay, then i will give it a try…
Mhh in Win 10 Notebook… it did. Not work still nothing happen… i will Try it in monday with win 7
