Christian Klings is an independent watchmaker from Germany. He has already made a number of really impressive watches. One of these watches particularly impressed me: the Tourbillon No.18.
The central part of the dial is made of silk fabric. The one-minute tourbillon is hand-wound. I repurposed the power reserve display to show the battery level.
Since C.Klings is relatively unknown, only a few pictures of this watch were available. Since the quality of these images was not sufficient for a good watch face, I reproduced it completely in the drawing program. The tourbillon in particular kept me busy for a while.
Enjoy and have fun.
Credits: -https://www.christianklings.com/
Download: -kling.zip - Google Drive
Worth the wait. Superb mate
Thank you, mate. It was a lot of work. Have you noticed that even the reflection of the light on the chrome rings of the hands follow the light?
Without question, one the of the most spectacular restorations I’ve yet to see… Well done @G1NT0N1C
Thank you, @pablo11 . It was a lot of work.
Beautiful watch and clockskin! I am most impressed that you reproduced the images completely in a drawing program. I have absolutely no idea how to create a homage watch face without a good image to work with! (Or perhaps I should say I lack the necessary skills and knowledge to do that.)
Thank you. My approach is as follows: First of all, I look for some images. the higher the resolution, the better. Then I enlarge this to around 6000×6000 pixels. I tilt, rotate and stretch these images so that I get the roundest possible result, which I then cut out and reduce to exactly 4000×4000 pixels. Ideally, I have around 3 such images, which I then place on top of each other on three different levels.
I now put together a base from these. Once this work is done, I will move some individual parts if necessary.
Once this work is done I can begin to recreate each individual part based on the template. By the way, I always create watch faces in the 4000×4000 format, as this allows for more precise work. Only when everything is finished do I reduce the size to 400×400 to put the individual components together in WFD.
Oh, now I understand. I assume you use three levels because each may have hands (obstructions) at different spots so you can combine the unobstructed parts into one? That’s interesting, I’ve never done that. I look for the best starting image I can find, rotate and stretch as needed as you described, then I remove all the moveable parts (hands, moons, gears, etc.) for separate use, then go through the laborious process of repairing all of the missing areas of the base dial, with a lot of copying and pasting and rotating and resizing and painting until I’m satisfied (or until I’ve reached my limit in ability or diligence). As you do, I downsize the images at the end if needed.
What size do you use for image editing?
I will use whatever resolution the source image is. I don’t upsize it or downsize it, until downsizing later in the process after all the image editing is done. I look for a source image with good enough resolution, as high as possible.
