Jan 11, 2018 11:38:21 GMT 1stanky7 said: Hello people 🍻 i lost my charging cable.
Please post links where i can buy a new one...
EU if possible, if not anywhere would be ok too.
Does any one know would charging dock for
LES 1 work with mine IQI i4??
I look forward to your help and replys.
Best regards to you all from Croatia.
With respect,
Dejan Stanić
My experience with the ZeBlaze Thor, which is similar to the LES 1 says that the charging dock will not work. The connections are reversed and not compatible and it physically will not fit due to the smaller diameter of the I4. You might try Ali-Express for a new cable. I don’t think they have one specifically for the I4 but the KingWear cables should work. My cables from the KW18 and Kw08 watches I have work with my I4 Air. Also the Microwear H2 cable will work.
