Question to everyone: does anyone use powerbanks with their watch?
Do you guys charge your watch mid day?
I charge mine once a day ( in the evening ). When I am not at home I have a powerbank in my pocket in case of running out of battery.
May 2, 2017 1:59:57 GMT 1 jghdfu3y said:Apr 28, 2017 16:09:51 GMT 1 mgk said:
even then, wont it take a lot of time for it to charge?
As this case happend once, I have no big experience - it took an hour to load the D5 when I remember right. But I could test it if you like ?
Charging the No.1 D5 with Jackery Mini 3350mAh External Charger.
Wifi and 3g always on.
Here are the results:
starting at 30 % :
after 10 minutes : 43 %
after 20 minutes : 60 %
after 50 minutes : 100 %
Seems to be the same as if you use the normal charging at home.
May 4, 2017 16:30:37 GMT 1 mgk said:
Charging the No.1 D5 with Jackery Mini 3350mAh External Charger. Wifi and 3g always on.Here are the results:
starting at 30 % :after 10 minutes : 43 %
after 50 minutes : 100 %Seems to be the same as if you use the normal charging at home.
