Changing apk\res\values\public.xml ?
I wanted to change the order of the hands from h/m/s to m/h/s…
I changed the public.xml (as above) but it didn’t make a difference… see the bottom pictures…
I look forward to somebody telling me why it didn’t work…
Just from looking at it. The HEX values are in the same order on both (04, 05, 06), try swapping the HEX order instead of the image. If that doesn’t work, then I suspect the drawing order is locked for those hands.
I’ll keep looking at it… I’d like the smaller hour hand to pass in front, not behind, the larger minute hand… at the moment I’ve redrawn the hands by changing the sizes of the concentric centre rings… in CSW I can simply reorder the layers…
Hey, can you pls send my this WF?
But with h/m/s
Hi michaelg… it’s in the custom faces section…
