Change firmware on Thor Pro 5.1 to improve wifi and Bluetooth
Hi everyone,
I have a Thor Pro 5.1 and it has a very poor wifi and Bluetooth connection.
Can a KW88 firmware be installed and will it improve wifi and bluetooth connection?
I don’t mind losing BT calling.
With very few exceptions, the firmwares are not compatible. And bad reception is usually not a software problem, but a hardware problem.
I don’t understand why it has bad connection problems since its antennas are in the bands!! Which firmware, other than Zblaze, is compatible with this smartwatch?
I have this watch also . Basically its a poor watch with poor hardware . My connection also isnt good . If a firmware was available it wouldnt make any difference
I had 5 zeblaze watches. They all died, in different ways. Zeblaze watches often have broken antenna cables because they are in motion. If the WiFi reception is very bad, I guess a cable break.
Thanks for all of your comments!! Which affordable smartwatch has the best wifi and bluetooth connection?
You might have a look at the Kospet Prime SE.
Please take a screw driver and tighten all the screws in the bottom plate and band.
I tighten the screws on the watch and the bands and no change.
I’m going to look into the Kospet Prime SE.
