Since yesterday, without reason, my H2 shown this error while opening the camera app
Cannot connect to camera
try to flash it with the firmware if it is software issue the flashing should fix it if not that means hardware, have you checked inside the watch?
Nov 29, 2018 17:32:59 GMT 1 soniasophie9697 said:pycon
Ehm no… what can I check ?!
disconnected cables. did you install anything before it started? watch fell?
Nov 29, 2018 18:31:07 GMT 1 soniasophie9697 said:pycon
Installed nothing Same as day before and week before. Rarely I use watch camera but latest time it worked normally, from yesterday no more
pycon the solution is to flash the watch.
I reflashed the watch but the situation was the same
PS Strange that on this type of smartwatches, it’s always impossible to restore the nandroid backup of DATA partition ! Anytime ‘ERROR 255’ at 90%…
Then I dismantled it, removed the camera plug cable. Clean with a little brush, high pressure air and replug it. And worked like a charm
