Can`t get a gsm connection
Hello and greetings from germany,
I can`t get a gsm connection. It only worked twice with the sim I use and now it says Sim (T-mobile and Vodafone) failure… The sim is ok in every other mobile.
In the FAQ i found the following:
""Why can’t I get a working cellular connection?
Usually it’s because the APN is wrong. (i’ll finish this answer later)
is that a point where i could fix something ??
Thanks,
Björn
Thanks,
Björn
check here and see if it answer your question, btw, have you checked everything is correct in cellular networks like APNs and even imei…
/thread/402/psa-another-friendly-reminder
/thread/368/psa-2016-data-issues-members
what is in these thread can be also the same for Germany, better you check it out.
