I use this to make phone calls. There is a flawless and separate button for the assistant. Your watch is also very good enough to turn on when you receive a call, connect immediately and pick up the call. It can be turned on with a switch, not a button. The connection is fast and your voice is clear. When turned off, the battery is good for several weeks.
i think its from android 9 the problems started…anyway, i do not have the time nor the ooomphf to do a complete reset…will buy a new headset i think…
