Breguet Marine Tourbillon Équation
Breguet has a decorated history in the maritime world, adding to it what is essentially a sundial (replaced in this version by the tourbillon). The watch indicates both times by means of two hands - one of which is a faceted golden sun. The date runs by means of a retrograde anchor-motif hand sweeping across an arc from nine to three o’clock.
THEORIGINAL:
CREDIT: Breguet.com
That is one beautiful watch face…and you have re created it magnificently doubedad! :+1: Cheers, Doons
Thanks, Doons, actually I was thinking of you when I did this and the face I made for you some time ago:
7SeasCopperBest
Yes, I still have this face (And another version I managed to make) on my watch. And now the Breguet Marine Tourbillon Équation is on there as well, perhaps I should start a nautical section on my watch and be done with it! :thinking: :laughing: Cheers, Doons
Perhaps you served in the Navy? If not, they’re always looking for volunteers!
It is a beautiful watch face but it doesn’t show the anchor-motif to denote date on my Kospet Prime. I am using stock launcher.
RK
Sorry, I should have noted that it does require the use of the universal launcher.
Ohh……Ok
Its a beautiful watch face. Can you port it for stock launcher as well? If the horizontal bar in the inner smaller circle (I don’t know what it is called) is not supposed to do anything, then only the date-indicating ancher-motif is not working or visible.
RK
The “anchor” points to the retrograde day of the month, a feature not supported by the stock launcher. Many cool features are available when using the universal launcher… Give a look!
