Bootloader or Recovery Mode?
Does anyone know how can I reboot this smart watch to bootloader or recovery mode?
I tried all the combinations of the two hard buttons but without any lack!
If you can’t do that wait till your battery percentages goes to 1-15% . From 1% to 15% range your watch function properly in that period you can go to setting and reboot. Sometimes it might not work until your charge completely get over, in this case re charge and follow what I said in the beginning.
The problem I have is that my watch doesn’t work properly any more. I can only access the power menu and nothing else! No watch faces, no apps, nothing at all! You can see a small video here:
Any ideas?
Get yourself the 4 pins data connector and flash the firmware again
I have ordered a data cable and I will receive it soon. Can you please give me details? How can I flash the firmware? Which is the procedure?
Do a bit of searching in this forum. It has been described dozens of times
Look our YT channel tutorial for flashtool instructions. But as usual, if you have settings app in your recent app icon, then you can do the factory reset.
Thank you very much for your help, dear friends!!!
