Bluetooth problem with KW88
Hello, i have a problem with my WiiWatch app. I am using the last firmware KW88_CS1_B_GSM_PHT_20171111 on kw88, and trying to pair it with Sony Xperia XA Ultra.
I made everything like in the instructions but the problem is that when i turn off the bluetooth on my kw88, and start it again, the wiiWatch app can’t find the watch, i don’t know where is the problem, tryied many things but no result. Maybe there is any other good apps? I want to get heartbeats and many other sport things to my smartphone from kw88 not just notifications.
Jan 5, 2018 19:01:02 GMT 1 sovredbit said:
Hello, i have a problem with my WiiWatch app. I am using the last firmware KW88_CS1_B_GSM_PHT_20171111 on kw88, and trying to pair it with Sony Xperia XA Ultra. I made everything like in the instructions but the problem is that when i turn off the bluetooth on my kw88, and start it again, the wiiWatch app can't find the watch, i don't know where is the problem, tryied many things but no result. Maybe there is any other good apps? I want to get heartbeats and many other sport things to my smartphone from kw88 not just notifications.
are the watch and phone paired?
Yes but i removed the pairing and still nothing
But 2 days ago i got phone and smartwatch paired using bt, and wiiWatch was able to find them, i don’t know how this app works, its very weird
Jan 5, 2018 19:23:50 GMT 1 sovredbit said:
But 2 days ago i got phone and smartwatch paired using bt, and wiiWatch was able to find them, i don't know how this app works, its very weird
check for updates for the wiiwatch if you still having problems try and see if it works with other device.
No new updates, need some time to find other Android 5+ device
i can’t really say that there is any good progress but other phone i think it has the same problems with wiiWatch, it sometimes connect sometimes can’t find, don’t know maybe its the phone problem, maybe smartwatch maybe app problem, any suggestions?
Jan 7, 2018 12:30:02 GMT 1 sovredbit said:
i can't really say that there is any good progress but other phone i think it has the same problems with wiiWatch, it sometimes connect sometimes can't find, don't know maybe its the phone problem, maybe smartwatch maybe app problem, any suggestions?
i decided to try both the bt app for calls and the wiiwatch on my kw99 with note5 and it works fine no disconnetions.
Wow that’s very weird
Jan 8, 2018 22:12:04 GMT 1 sovredbit said:
Wow that's very weird
the only downside that if i connect both of them to headset and bt calls app is on the headset disconnect from the watch and calls come only via speaker:/ sad....
same for me, I have upgraded KW88 to the last frame-ware KW88_CS1_B_GSM_PHT_20171111, while pairing with my cellphone Mi Max, the BT connection is drooped after a while,eventually,No BT Calls notifications are appear in the KW88!
I think it’s a frame-ware issue, hope to be fixed in the next frame-ware run-update.
Regards,
Tareq
