Apr 10, 2019 11:30:20 GMT 2 pablo11 said:
Otherwise you will not see any changes. The test is definitely going to need BT to be activated.
Done and yet nothing new: the MAC address it's still the "fake" one "00:00:46...".
Apr 10, 2019 11:32:04 GMT 2 marioerased said:Apr 10, 2019 11:30:20 GMT 2 pablo11 said:
And is it the same when you connect to another device or does the MAC change again?
Always the same MAC as the I8, the same MAC it was before and the still the same after connect to a device, both smartphone or BT earphones:
00:00:46:00:00:01
This is amazing…
As iscle said as well - it’s very strange indeed.
What version of the I8 is it? The M6737 model or the m6739?
Apr 10, 2019 11:48:39 GMT 2 pablo11 said:marioerased
This is amazing…
As iscle said as well - it’s very strange indeed.What version of the I8 is it? The M6737 model or the m6739?
Apr 10, 2019 12:02:57 GMT 2 marioerased said:Apr 10, 2019 11:48:39 GMT 2 pablo11 said:marioerased
This is amazing…
We've checked with CPU-Z, it's the mt6739 version, android 7.1.1.
anyway, the FW version you posted it’s not the latest, because on the 20190320 version there is a new option “Notification bright screen” into display settings.
Trying to check software updates doesn’t show the new version tho.
Apr 10, 2019 13:00:13 GMT 2 marioerased said:pablo11anyway, the FW version you posted it’s not the latest, because on the 20190320 version there is a new option “Notification bright screen” into display settings.
Apr 10, 2019 13:16:43 GMT 2 marioerased said:Apr 10, 2019 12:08:34 GMT 2 pablo11 said:
Ok. Well, the next step is to do the same process with the I8. Sorry but we have to start with the basics.
I can't force my colleague to flash his watch and he doesn't have the firmware zip
Anyway, no worries…
It’s up to you.
Can you tell me the exact firmware version is on the IQI I8 please?
Apr 10, 2019 13:50:18 GMT 2 pablo11 said:marioerased
Apr 10, 2019 14:35:48 GMT 2 marioerased said:Apr 10, 2019 13:50:18 GMT 2 pablo11 said:marioerased
Build number: IQI_I8_B_AUO_V1.0_20181013
Apr 11, 2019 11:02:35 GMT 2 marioerased said:Apr 10, 2019 14:42:47 GMT 2 pablo11 said:
Thank you
Eventually, my colleague should flash the same version? Where can he take the ROM zip?Thanks
Because we have found the original rom on a dedicated topic on forum.
Ok, I own this forum and I get my firmware directly from the manufacturer.
Which thread are you talking about with different firmware?
I will be linking you to the original stock firmware which is exactly what I did with the Hope firmware.
Here is the original IQI I8 firmware - use it or not if you don’t trust me.
drive.google.com/file/d/1aNTs4eJ96L_fjoMmNQad5hXm2nPK9e2F/view?usp=sharing
Pablo11.
Apr 11, 2019 13:16:25 GMT 2 RASC Moderators said:
Here is the original IQI I8 firmware - use it or not if you don't trust me. drive.google.com/file/d/1aNTs4eJ96L_fjoMmNQad5hXm2nPK9e2F/view?usp=sharingCheers
Pablo11.
I wan not talking about a different firmware, I only asked if the firmware you will be linking is the same on topic “http:///thread/3022/i8-m6739-fw”, which it is
thanks!
We tried to flash the firmware on I8, with “Firmware Upgrade” option and nothing changed.
Also a data factory reset didn’t fix.
