Bluetooth les1
Good do not know if someone else has the same problem but I’m having bluetooth connection problems instantly connect and pair the smartwatch and the mobile is disconnected and there is there’s no way to stay connected, help, thanks.
Nov 29, 2017 1:34:19 GMT 1 juse said:
Good do not know if someone else has the same problem but I'm having bluetooth connection problems instantly connect and pair the smartwatch and the mobile is disconnected and there is there's no way to stay connected, help, thanks.
make sure that in power saving nothing is marked or on.
I have already checked the energy saving and restarted it until I have resumed again by flashtool but I still have the same problem.
try and see if it happens with other bt apps.
I had the same problems and my the solution was did reinstallation of firmware through sp flash tools.
