good day, I bought a hem 7 everything is ok but when I plug in the bluetooth headphones are still interrupting, they only work for 0,5 m
try with bt speaker and see if same results.
It does the same, interrupts the signal, more than 1m
checking…
Oct 1, 2018 11:56:41 GMT 1 soniasophie9697 said:dsarik
checking…
Can you explain in addition?
Never tried my Lem 7 with BT headphones so decided to try it now. Paired BT earbud and played music for about 15 minutes no problem. Not sure how your watch is set up but could several things affecting it I would guess.
thanks, i’ve had only the options to check are with the i8 or i7 and so far they showed me good connection even if i’m far about 5m.
Oct 1, 2018 14:17:36 GMT 1 soniasophie9697 said:capt jon
You’ve got long arms!
evo1rs sorry??
