Is 1 the phone app & the other the watch app? Unable 2 try @ the moment. Will b 2mora now, I will let u know how it goes. Again thanx 4 ur help.
Hi . Yes , one for phone , one for watch
Sorry 2 bug u again Tim but which is which because they both say watchdroid phone with 1 saying premium
Really sorry . Post ammended ( my mistake ) . Assistant is for watch
Cheers Tim
Will try it later
Hi Tim. Installed your Watchdroid Phone & Assistant. Unfortunately itâs pretty much the same, connecting & disconnecting. What I have noticed is they stay connected when the watch assistant app is open on the watch & when u come out of the app but as soon as the watch goes 2 sleep the connection is lost
Hmm, that sounds exact like an wellknown problem. Sorry for asking, but have you checked this?
Watchsetting - more - backround Cleaner- tap in Batery saver - disable watchdroid Assistent?
If yes, sorry for asking. Then I just have one idea leftâŚ
The only thing that usually makes that happen is the app sleeps and loses connection . Myself and @G1NT0N1C have asked a few times if you have 100% disabled in battery saver . Can you confirm this
Well, I had the same problem once. I could solve it, in which I
- deleted all the appâs data on the watch (watchsettings - uninstall aplication - choose watchdroid - end aplication - tap storage - delete data - then delete aplication).
- same procedure on your mobile.
- then goto bluetooth setting and delete device.
- After that reinstall the apps on your phone and your whatch.
- pair it again as desciped. (No Bluetooth pairing).
- At least restore the needed settings (disable battery saver etc)
Lads u r fantastic, I carried out G1NT0N1Câs instructions going into background cleaner then into Battery Saver. Sorry Tim I know u mentioned it a couple of times but I didnât know how 2 do it, my apologies
But allâs looking good now.
Do either of u know what could possibly of happened because it must of been set correctly b4 because it was working 4 ages without issue.
Could it of had anything 2 do with when I updated Clockskin Randomizer? Which I have now uninstalled.
I donât think so. Try it out.
Success
. If you ever get stuck dont be afraid to ask . Thanks for the kind words
Cheers Tim. Too scared 2 reinstall it, lol. Thanks again to u both 4 all ur help.
Fair enough but the version i sent you is much better
Yes, thanks 4 that I have installed that I was referring 2 clockskin Randomizer app.
