Some of you already mentioned that bug when someone calls, even if you are conncted to BT headset, after answering the call, sound is transfered back to watch.
I’m trying some apps that force BT connection, alternative dialer, but nothing works out.
However, if someone call to you and You answer by button on your headset, it work fine.
Do you guys know the way out?
