Bluetooh Isues
Hi everybody. I need help with my h2. Last days i been having problems with BT. It disconects several times at day. I don´t know why. I checked battery saver, uninstall and install again. I use BT all day because i don´t have sim card and use the watch to see important messages from my phone. I am very sad with that. Can somebody help me?
Need more information to help you. Which tethering app are you using? Does your watch have BT call app installed? Also suggest you read all the posts regarding BT connection problems for suggestions on troubleshooting your problem.
Thanks. I have tested with several apps. Wii Watch, Watch droid and M2D. I have BT call app installed too. But it´s strange because in first days i don´t had problems. Right now, i have installed watch droid and have more than 3 hours of continuos connection, but yesterday the situation was different. I´m so confuse. I usually power off the watch in the night and let charging. Today when I turned on the clock it showed me the application restart message that comes out when an Android update is installed. The issue is that previously I had already verified the updates and there was no pending. Then I wonder if it could be that by some situation when I restarted the watch it did not restart well and that could be what caused the problem. I'm going to review the other post about the bluetooh problems that you told me about. Thank you very much and sorry for my english.
Thanks. I have tested with several apps. Wii Watch, Watch droid and M2D. I have BT call app installed too. But it´s strange because in first days i don´t had problems. Right now, i have installed watch droid and have more than 3 hours of continuos connection, but yesterday the situation was different. I´m so confuse. I usually power off the watch in the night and let charging. Today when I turned on the clock it showed me the application restart message that comes out when an Android update is installed. The issue is that previously I had already verified the updates and there was no pending. Then I wonder if it could be that by some situation when I restarted the watch it did not restart well and that could be what caused the problem. I’m going to review the other post about the bluetooh problems that you told me about. Thank you very much and sorry for my english.
About this problem I solve it by extracting the sim card and using the smartwatch only by bluetooh. Now the disconnections are less frequent than before.
I bought a smart watch Microwear H2.Connect a headset (six different tried)for about three minutes all is well and then shuts off the headset, then Bluetooth, then back to all plugs, tried all that is possible.
On the smartphone install the Watch Droid Phone from the Play Store, and at the clock, install the Watch Droid Assistant.  In the settings on the - Watch Droid Phone, tick the box - Do not sleep for clock. After I did this, the Bluetooth connection between the smartphone and the clock was not interrupted.
Я купил смарт-часы Microwear Н2.Подключить гарнитуру (шесть разных пробовал)в течение примерно трех минут все хорошо а потом отключает гарнитуру, а потом блютус, потом обратно все разъемы, попробовал все что можно.
На смартфон установить часы дроид телефона из магазина Play, и на часы, установить часы дроид-помощник. В настройки - часы дроид телефона, галочки - не спать часами. После того, как я это сделал, Bluetooth-соединение между смартфоном и часами не прерывалась.
And the headset bluetooth won't turn off?
I wrote to you about the application that connects your smartphone and your watch. I do not use a Bluetooth headset, so I can not say anything about it. Check.
i never had issues with any headset to stay connected to the watch, are you using the bt calls app? are you connecting the headset to watch and phone together?
I want to use the watch as a phone.So the headset is disconnected when the clock goes to sleep, even the video was shot for the seller
Much depends on the Bluetooth headset itself. Maybe the headset does not keep a stable connection with the clock. And Sonia wrote to you correctly: Check the connection through the application on the clock - Bluetooth call
that is just not right again i'm using BOSS and JBL headsets with my watch and never i've had disconnections honestly one of the best watches i've used even when i workout outside i do'nt have any issues with bt connections. check if the bt calls apps is on, if you can and have another headset check it with the watch and also it might a faulty watch which has a bt problem.
The watch is just great and the GPS works well and in General everything is good only with Bluetooth problems.Tried 6 different headsets and all the same .Noticed by chance that when flucan WI FI headset not disconnected.It’s probably a software problem.I don’t know what to do anymore .
Apr 18, 2018 19:19:38 GMT 1 vitaliy75 said:
The watch is just great and the GPS works well and in General everything is good only with Bluetooth problems.Tried 6 different headsets and all the same .Noticed by chance that when flucan WI FI headset not disconnected.It's probably a software problem.I don't know what to do anymore .
you have'nt answered the questions i've asked, do you use the bt calls app? are you connected with the headset to both devices at the same time?
No use for me it is inconvenient and there is no need,I told you that I wanted to use as a separate device.
vitaliy75
are you using the bt headset for music or just leave it on for calls? you need to remember that my headsets turn off when there is no activity not just with my watch but also with my phone.
Bluetooth headset should not detach from the watch.Clock is essentially the same phone on Android.Bluetooth headset is not disconnected from the phone in sleep mode .so, joke’s a software problem.which I can’t decide on this and ask .
Hi Vitaly! In case you haven’t checked this already try to change smartwatch plataform (iOS vs Android) to check behavior…
that is just not right again i’m using BOSS and JBL headsets with my watch and never i’ve had disconnections honestly one of the best watches i’ve used even when i workout outside i do’nt have any issues with bt connections. check if the bt calls apps is on, if you can and have another headset check it with the watch and also it might a faulty watch which has a bt problem.
Hi Sonia. Could you tell me what firmware version do your watch have? Is it the last one in this forum? I have 20171024. Thanks
i'm using mine also as a separated device and do'nt see any bt issues with the headsets i have.
