So considering what RASC said, all we have left to do is test applications that best manage battery consumption, am I right?
And anyway, is there any safe way to root on thor and try to improve the battery?
Thank you all!
Feb 28, 2018 15:03:35 GMT 1 recrossmusic said:
So considering what RASC said, all we have left to do is test applications that best manage battery consumption, am I right? And anyway, is there any safe way to root on thor and try to improve the battery? Thank you all!
what is your usage? you should get almost a full 24hrs of usage with it.
I changed the battery on Zeblaze Thor, 350mAh with 500mAh. Watch, use 3 hours WIFI connected with app AirDroid, GPS one hour, changed clockskin…all in 15 hours. I’m excited. Watch finally works …
Mar 24, 2018 23:49:37 GMT 1 trener said:
I changed the battery on Zeblaze Thor, 350mAh with 500mAh. Watch, use 3 hours WIFI connected with app AirDroid, GPS one hour, changed clockskin.....all in 15 hours. I'm excited. Watch finally works ....
Please post the link to 500mAh battery. I would like to try the same.
m.aliexpress.com/item/32832146569.html
BR
Trener
Mar 28, 2018 21:03:34 GMT 1 trener said:
m.aliexpress.com/item/32832146569.htmlBR
Trener
Thank you!
Any more updates on battery life? Did the watch give you more run time?
The battery lasts one hour longer when I use GPS, 30 hours longer like watch. Battery capacity is caa. 400mAh.
I suggest that you root the smartwatch and with the app Sistem app uninstaller ( play.google.com/store/apps/details?id=com.ljmobile.system.app ) delete everything you don`t need on your smartwatch. Applications works in the background…
Maybe the app Greenify (https://play.google.com/store/apps/details?id=com.oasisfeng.greenify&referrer=utm_source%3Dxda%26utm_medium%3Dpost%26utm_term%3Ddownload ) , stops running applications in the background.
Your choice.
Greetings from sLOVEnia.
TrenerReports on the Ali site tested it at 350ma.
So can someone please tell me??? Is there a link to a replacement battery for the Les1 ?
I kinda see no point in this thread if ultimately theres no battery available
gonk59
Jun 4, 2018 13:06:34 GMT 1 gonk1959 said:
So can someone please tell me??? Is there a link to a replacement battery for the Les1 ? I kinda see no point in this thread if ultimately theres no battery available gonk59
of course you can but the question can you replace it?
something like this: www.aliexpress.com/item/3-7V-600mAH-562438-Polymer-lithium-ion-Li-ion-battery-for-DVR-RECORD-MP3-MP4-TOY/32816647495.html?spm=2114.search0104.3.255.466d2455YIEfRL&ws_ab_test=searchweb0_0,searchweb201602_2_10152_10151_10065_10344_10068_10342_10343_10340_10341_10696_10084_5722520_10083_10618_10307_10059_5722620_5722920_5722720_5722820_100031_10103_10624_10623_10622_10621_10620,searchweb201603_36,ppcSwitch_4&algo_expid=de17a42e-760f-4bb5-98a9-51c6ccd1b78b-38&algo_pvid=de17a42e-760f-4bb5-98a9-51c6ccd1b78b&priceBeautifyAB=0
seb84 might be more helpful on that:)
can use this one, if i see right on the pics its 503030
if you need more help pm me
I changed the battery on Zeblaze Thor, 350mAh with 500mAh. Watch, use 3 hours WIFI connected with app AirDroid, GPS one hour, changed clockskin.....all in 15 hours. I'm excited. Watch finally works ....If someone is prepared to make a video or detailed write up - we should make a sticky thread for this
Jun 23, 2018 5:14:39 GMT 1 RASC Moderators said:Mar 24, 2018 23:49:37 GMT 1 trener said:
There are still pictures i dd with my lemfo lem5 somewhere here in the forum
£31.36 5%OFF | new arrival Rechargeable repalcement Battery For zeblaze thor 4 4G Smart Watch GPS wristwatch phone watch clock hour battery
