How can we setup the battery rotate to make an arc not only 180 or 360?
In ClockSkin Maker gui for windows is working but when i try on d5+ (w613 last firmware) is noy working. Is away from the position where needed area is.
Jan 26, 2017 18:56:14 GMT 1 lucian said:
How can we setup the battery rotate to make an arc not only 180 or 360? In ClockSkin Maker gui for windows is working but when i try on d5+ (w613 last firmware) is noy working. Is away from the position where needed area is.
Hi, I'm using ClockSkinMaker, but I didn't understand how to create the file .vxp for the WatchFace I've done. Can someone help me?
Feb 24, 2017 19:40:48 GMT 1 cisco said:Jan 26, 2017 18:56:14 GMT 1 lucian said:
you're asking in the wrong place:) what watch do you have?
try to ask in the right section to get more replies.
I’m quite new, can you link me the right section?
Feb 24, 2017 20:37:25 GMT 1 cisco said:Feb 24, 2017 19:49:07 GMT 1 soniasophie9697 said:
yes, which watch model do you have?
the no.1 g6
Feb 25, 2017 16:58:22 GMT 1 cisco said:
the no.1 g6Thanks
sorry but the watch faces here are for full android watches and not for your watch, you can check no.1 site to get more watch faces for your watch or check Youtube:)
/thread/613/rotate-battery-test
