In airplane mode of course good battery life but you cannot phone or receive calls…
Oct 15, 2017 18:05:30 GMT 1 kiki301 said:
In airplane mode of course good battery life but you cannot phone or receive calls...
true, try to see on apps what is running and stop the ones that you do'nt want to run like ios and other stuff, i have S1 mtk6572 only dual cores and 3g always on and battery life is just great, but mtk6580 is more battery efficient so you should get way better battery life how was the watch before any update?
true, try to see on apps what is running and stop the ones that you do’nt want to run like ios and other stuff, i have S1 mtk6572 only dual cores and 3g always on and battery life is just great, but mtk6580 is more battery efficient so you should get way better battery life how was the watch before any update?
I heard the mtk6580 had way worse battery life than the mtk6572, mainly the 3G used a lot of battery if im correct.
Oct 15, 2017 21:26:06 GMT 1 yotoprules said:Oct 15, 2017 18:58:08 GMT 1 soniasophie9697 said:
the problem is not the mtk6580 but rather the SW, true i noticed that 3g on my watch which is mtk6572 and on my D5 which also mtk6572 battery life was better than on my x3+ but just after i’ve updated my watch battery life was just awful. install this app and see if your watch is going into deep sleep or not and see if all cores are working
play.google.com/store/apps/details?id=com.a1dev.cputool&hl=en
on my watch it does’nt but the truth is that i go in to apps settings and stop what is needed on my x3+ the ios app always was running and i had to stop it every time i finish charging the watch. if your watch most of the time is’nt going into deep sleep then something is keeping the cpu awake.
Where can I buy a new battery for Les1 or Thor with more capacity?
