I had an update made last week.
Before, I was using the watch only with WiFi & Bluetooth connected to my iPhone. I was using the watch for more than one day, in Plane mode, allowing only WIFI & BT.
Since this update, and I really think there is something wrong with this new version, it works fine for 1 hour or so, and within 2 minutes, the watch turns off, and the battery is à 0% !!!
I have my KW 88 now for 5 days and at the beginning I was really happy with the performance, BUT:
even when switching off GPS and DATA the battery life is abyssmal … and it seems to be a core-problem: yesterday I diconnected from charger at 8am and had still 75% battery at 5 pm …
“Fine”, I thought, “I can live with switching on DATA and GPS only when I really need it”, but once again when checking time one hour later (6pm) I had to find out, that the watch turned off meanwhile because of no juice ( I changed nothing in the settings).
And this behaviour was replicable every day since I got it 5 days ago: Battery goes down to approx. 50%, You think You are still fine, but then after some 30 minutes later You have to find out it switched off because of no juice (showing 1% when connected to the charger).
Tried the procedure as described by rsk01 in another KW88 battery-thread post and it worked for one day.
I was happy and I thought: now my KW88 works similar to my old (and battery - broken and fully charge-contact-corrosion after 2,5 years) Gear S.
Yesterday I left home at 6am, battery consumption until nine was down to 66% (Data, WLAN and GPS OFF, screen birghtness: LOW) and when 30 minutes later I wanted to check the time I found that KW88 switched off again.
Now I am finally totally fed up with this Smartwatch and I send it back …
Have you checked to see if your Heart Rate Monitor is going without actively going in & turning it on?
I had this exact issue at work tonight. Last time I looked at my KW88 it still had 79% battery then next time I looked at it some 15 - 20 minutes later it was 4%… I thought to myself “What the actual funk!?”
So, I turned it off, put it in my bag & just thoughtŕ t þř I’d figure out what was going on when I got home?
Got home & connected the charger & within 5 seconds the heart rate monitor came on & stayed on. No blinking, nothing! Just a constant stream of green light coming from the HRM? I thought to myself that was probably the cause of the rapid battery life decline but now I don’t know what to do about the continuing heart rate monitor being on…?
I can’t charge it without it staying on the whole time so what do I do?
The reality is you have to keep clearing google data after you have used playstore etc . Read link above . It really works and if problem returns " do it again "
Some watchface could drain your battery, at least thats what happened to my kw88. So I chose a non animated watchface. And in this 3rd day, my watch is still on, showing 31% of battery. No sim card, turn off wifi, gps, waking up gesture, clear all recent task.
