@mehul1 Thanks a lot, I’m using accubattery to warn me at 80% charge and 3c battery manager to warn me when battery is at lower than 3% and phone temperature reachs more than 40ºC. I should be a electrical engenieer to understand those graphs
I have just read a fast charging article where explains:
“Wattage, or power, is computed as a result of current (A, or amperes) multiplied by voltage (V, or volts). Current is the amount of electric current being transported, while voltage is the force that drives this current forward. Therefore, 3A/5V charging will deliver 15W of power.”
Volts and amperes are measures of electricity.
A volt (is the unit of electric potential difference) the size of the force that sends the electrons through a circuit.
An ampere is the unit used to measure electric current. Current is a count of the number of electrons flowing through a circuit. One amp is the amount of current produced by a force of one volt acting through the resistance of one ohm.
Let’s check 3c battery manager chart
We can see at bottom next column fields: date, hour, mA,% ,mV and temperature (ºC) you can see these fields in historic log so:
mA are the ammount of electrons flowing
% remain battery
mV Size of force which battery is pushing electricity
ºC Battery temperature,this is what it matters to me, I have ranges from 34.4ºc to 37.7ºC, my alarm in 3c battery manager chart is when battery is over 80% of charge (battery degradation according to these apps, you should charge between 0 and 80% but I will charge at 1,2 or 3% if I get notification or I hear alarm sound, last time I didn’t, that’s the reason second alarm is battery % is under 4% and I will create another ones at 3% and 2%) and the most important when you charge (I don’t know if fast charge matters for reach higher temperatures) I configured alarm for temperature higher than 40%.
Which is funny is that 3c battery manager chart, accubattery and system battery reports me different about what apps are wasting more battery, take a look these images:
What I have clear is that Always on Amoled is one of tiers because phone is “sleeping” with that lock app most part of time and also it should be also music player, I use it at these hours to listen music (instead of computer
because I have a ssd connected to phone)…
Regards and thanks
