Hello
Any suggestions to my problem of battery consumption?
This is not normal.
In mode airplane…
I happen to someone else?
Hello
This is not normal.
In mode airplane…
Try installing gsam to analyse which apps are draining your phone. You can also install amplify to block some wakelocks.
Oct 24, 2016 16:38:41 GMT 1 madakite said:
I installed the app, tonight I disconnect the charger and put it in airplane mode.
And I look when I get statistics.
In my case (average use time 6-8 hours) …analyzed the battery use with gsam and I found that Ios push used 11.5% of the battery and I am not even using an Iphone…so I disabled that and will see if battery life gets any better…btw I am using Finow X3+ with the latest OTA
Oct 25, 2016 19:52:30 GMT 1 mkolev said:madakite how did you manage this kind of consumption
Oct 25, 2016 22:14:39 GMT 1 soniasophie9697 said:
Oct 25, 2016 20:52:27 GMT 1 madakite said:
so the watch is ok now?
Yes
In my case now the most draining app or service is the Ios push notification…any ide how to disable that? I know how to stop the service but it still continues to drain battery
…Still draining battery…If you disable the notifications,what is this procedure running for?
Oct 27, 2016 4:34:37 GMT 1 smith said:
.....Still draining battery....If you disable the notifications,what is this procedure running for?
Guys, there are ways to see what is causing the battery draining:
Possibly root the watch and remove those unused system apps.
yeah,first of all ROOT.Just what I did on my phone,rooted,uninstalled the system apps.
That model has made root?
Following the tutorial from here?
